Eastside Cruisers • View topic - For Sale: Borg Warner diff suits LC/LJ Torana
It is currently Wed Jun 26, 2024 10:11 am
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 6 posts ]
PostPosted: Sat Apr 30, 2011 4:56 pm
For Sale:
Borg Warner diff to suit LC/LJ Torana
Complete - ready to bolt in
All work professionally done by Keysborough Diffs
Mini spool
28 spline axles
3.23 ratio
Disc brakes
Slotted rotors
Torana stud pattern
It is standard R31 Skyline length, so that means its about 20mm longer than std Torana length either side.
This is not a problem with the right offset wheels. I used ordinary 14" or 15" steel volvo rims without any problems.
I also have some custom widened (15x8") volvo rims, which I can sell too if interested.
I spent the money to get this diff built properly and it has new street-friendly gear ratio.
$1200ono
Ph 0421 112 348 (Scott)
PostPosted: Sat Apr 30, 2011 5:35 pm
does it come with brand new wheel studs does any one no how much power the borgies can take a mate of mine has just dropped a 383 into a lj i think he might have trouble with the 10 bolt he has in it
PostPosted: Sat Apr 30, 2011 5:53 pm
Yep, comes with new wheel studs. ;)
Borg warner diffs are pretty strong. There are 9 second VL commodores still still running BW diffs.
I also measured the axle diameter once, and they're the same size as a 9 inch axle.
PostPosted: Sat Apr 30, 2011 9:16 pm
Show us some photos of the LC with the new diff and wheels fitted Scott.
PostPosted: Sun May 01, 2011 4:08 pm
I still have a bit of work to do! To fit the new tyres I need to do some mini-tubbing.
But I've bolted the new diff if for now. But as you can see, it sits like a 4WD because the tyres hit on the inner guard.
PostPosted: Mon Apr 08, 2013 12:16 am
Hi mate,
Just doing similar mod to my Lc, can u fit those wheels without changing standard shock and spring mounts?
Thanks
Users browsing this forum: No registered users and 0 guests
cron
